Section analysis by component
odolyte
Message 1 of 33
odolyte
Right now, if i want a section analysis it will cut through my entire model like this :
But i would like to be able to add a section analysis for a component only in order to achieve this :
here, only the shell is splitted but everything else is intact.
It is very usefull when you want to see how things are working inside a mechanism without having only half the model.
We also need to have section analysis by component in animation mode and render mode.
Moebius Factory
Replies (32)
Message 21 of 33
RxCrush
+1 upvote
Message 22 of 33
jordy_keller
I ended up here because I was searching how to do this, only to see it's not possible... 5 years after the thread was posted.
Great, another workaround to add to my workarounds toolbox.
Message 23 of 33
nahim_elatma
The same thing happened to me as to Jordy. Two months later, I still not even an ack from the PM team at Autodesk or a roadmap ETA.
Message 24 of 33
MichaelT_123
Hi FFellows,
The Section Analysis, including the one for individual components/bodies, is perhaps one of the oldest topics on the forum, and it seems it will remain here for the foreseeable future.
In a separate post, I will present visuals of what Section Analysis might look like. Presumably, I will add some comments … which should be treated with … light acumen.
The post:
https://forums.autodesk.com/t5/fusion-design-validate-document/section-analysis-by-component/m-p/136...
Regards
MichaelT
MichaelT
Message 25 of 33
Woogie_Maker
Would love to see this feature
Create a Section Analysis Group > Add components to group.
Sounds simple enough, but I presume it would take a lot of work to code this.
Message 26 of 33
LIC_Homies
@autodesk you guys should get on this one.
It should be like in the extrude dialog box, within a Section dialog box you should be able to check which components or bodies are getting sectioned.
Don't leave us in the stone age! Let us make sexy images for presentations!
Message 27 of 33
aleksei_ovsienko
Not only this. But I would like to be able to use this section analysis on a drawing view rather than re-creating it again with drawing section tools.
Message 28 of 33
michaelHNBAA
Community Visitor
Community Visitor
+1 This would be helpful.  Would be nice to have a component selector in the section an analysis editor, or nested in the active component.
Message 29 of 33
rcflyr
I've given up on this ever being built.  They're busy building AI tools nobody asked for.
Message 30 of 33
Woogie_Maker
Never give up.
Maybe the team can use AI to build the feature for us. I'm sure it'll work perfectly on first release 🤣
Message 31 of 33
Phil.E
Thanks for the upvote and reminder.
Reference improvement ticket: FUS-242371
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
Message 32 of 33
john.daltry4URBQ
Similar to this the ability to change the opacity of inserted external components would be very helpful. It can be done in most other CAD I've used. For some reason body opacity seems to be linked to the file itself. It therefor needs a save and update to show in an assembly, frustrating to say the least. There should be visibility and opacity control per component in the assembly that is completely unlinked from the part file itself.
Message 33 of 33
Manuel_St_
Community Visitor
Community Visitor
+1, need this on component level, would be very useful.
