Sculpt workspace - Weld option in revolve
I'v modeled a planar T-spline surface and modified an edge.
I've then selected that edge as a revolve profile respect to Z axis:
I've activated weld option.
I was assuming it would weld planar surface and revolved surface edges.
It's not really the case, since editing revolved surface reveals that edges are not welded:
What is that option intended for ?
Alex
Accepted solutions (3)
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting in the community!
I tested this option to see how it should work but I was not able to see at this time.
So I am discussing this internally, and I will circle back here once I have information to share!
In the meantime, can you please try "Merge Edge" in the MODIFY menu on this if you have not?
Thank you.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
TrippyLighting
If you create a revolve where the vertices at the start,m or end (or both) align with the revolve axis, after the revolve is completed this would weld these vertices at the poles together.
patrick.miller
As Peter explained, the Weld option affects the poles of the revolved body. If they connect, the vertices are welded. I attached a video showing the difference.
Patrick Miller
User Experience Designer
Fusion 360 Learning
patrick.miller
Let's try that Screencast again...
Patrick Miller
Fusion 360 Learning
Thank you all for the answers and thanks to Patrick for the video.
