Sculpt - paint selection bug?
I have created a sketch one part is a spline. I extruded the sketch to a solid.
Then I went to Sculpt mode, choosed Modify-->Convert moved the mouse over the face create by the spline.
Then I activated the 'Paint selection' tool and selected a few faces.
Then I used the 'Edit Form' tool to push these faces downwards a littlebit.
So far no problem. Then I activated the 'Paint selection' tool again and tried to select the pushed down faces again.
But this does not work for some reason. I can only select those faces which I did not push down.
Then I did the same but this time I pulled up the faces. And here the 'Paint selection' works. It seems this happens only if I push down the faces.
I made a screencast of it to make it clear:
I have one more thing to complain but this is minor.
If I switch from Model workspace to Sculpt workspace the solid body gets a bright grey color.
Then if I activate Modify-->Convert to select a face to convert to T-Spline the selected face does not really distinguish from the other faces it is also very bright grey.
You can see it in the screencast at around 01:22. One cannot really see which of the faces are selected and which are not.
Is there any setting to make the colors more different?
Thanks...
