I'm starting to learn fusion 360. I modelled my item quit well (I think :)). Started with a box in sculpt mode and made my design. I choose the top plane to work on. My design was finished and I tried to print it on my 3d printer. It warped on the back of the item. If you look at the attachment you will see a slight offset on the x-axis. Thats why it warped. Don't know why it happened only there and not in the rest of the model. Probably should ground the bottom of the box to fix it in the future? I know in sketch mode you need to ground stuff. Do I also need to do this in sculpt mode? Anyway how do get the entire model flat on the x-axis so I can print it.
I hope I did not send a stupid question here. Sorry. Realy new to these things.
Thx
Kind regards,
Glenn
Anyway.
