I needed to create a Screencast from my laptop, which has a screen resolution of 1366x768. It appeared to create OK but I have a severe problem when reviewing it - I can't access the 'play' button at the bottom 'cos it's off the bottom of the window and there is no way to either minimise or move it up a bit to make the bottom visible.
Any clues?
Solved by LeonardoBN. Go to Solution.
Isn´t it possible to click and drag the SC window in it´s top area.
Can you make a screenshot?
günther
Hi @lemelman. I use the same resolution as yours, and only a fraction of the buttons is visible. Here I use Windows with a narrow taskbar. It is not ideal, but I'm used with this and I memorized the positions.
I only get full access to the buttons if I auto-hide taskbar:
First off, I'm sorry for the long delay in responding, but my laptop hasn't been available for a few days, but thank you for your feedback.
Günther, no matter what I tried, it was impossible to reduce the vertical size of the SC window.
Leonardo, eventually I was able find a setting that hid the Windows taskbar when not actually needed. With it hidden I was able to access the SC buttons OK.
I can now use SC on my laptop.
