Scoping Parameters
Scoping Parameters
banksysan
Scoping Parameters
banksysan
I have two gears with different dimentions, they're 100% parameter driven.  Can I scope parameters to individual components so I can use the same parameters for the calculated values but toothCount is different for each gear?
etfrench
Yes, you can use the same parameters on multiple gears.  Whether or not they will generate valid gears that will mesh correctly depends on your design.
ETFrench
banksysan
How do I scope them though?  I want NUMBER_OF_TEETH to be scoped to individual gears but the formulae for calculating radius to be common to all gears.
chrisplyler
Then make one parameter RADIUS_ALL_GEARS, and one each for TEETH_GEAR_1, TEETH_GEAR_2, TEETH_GEAR_3, etc.
etfrench
Attach your file to the thread (File|Export|Archive file *.f3d) for more help.
ETFrench
TrippyLighting
The functionality you are looking for is named "Configurations" in other CAD systems but in that form does not exist in Fusion 360.
So the same user parameter cannot have 2 different values depending on what Component it is used for.
The solution @chrisplyler posted works well enough the for a half a dozen different gears.
banksysan
Would scripting be the thing I should be looking at then?
