scketch a hollow cube
I am new to fusion 360.
When I use lesson 1 sketching , I will sketch a cube with bottom 2 mm and walls of 2 mm.
How can I sketch a lid of 2mm on it ?
Or must I use another part of fusion ?
Thank's if You can help.
Tom
SaeedHamza
Just use the model workspace
Create a new sketch on the top face where the lid is, and then extrude it as a new body
Could you share a picture?
Saeed Hamza
testtestThanks for Your answer.. here a image.
I want a lid on the front to close the box and it will be hollow.
Then I can print it with 3d printer for modelling.
SaeedHamza
Start a sketch on the thin face of the opened side
Then you'll have 2-profiles, extrude them to have your cover
I made a screencast, it's uploading
Saeed Hamza
SaeedHamza
Saeed Hamza
Thank's for Your help.
Post can be closed.
Tom
SaeedHamza
You need to accept it as a solution
Saeed Hamza
