Scaling Problems
Scaling Problems
SlawsonEngineering
Scaling Problems
SlawsonEngineering
I am trying to get a dxf of a decal design to import since the decal feature wouldn't scale right.  Now I am having scale issues with the dxf.  I extruded the dxf to a set thickness, but when I try to scale it non-uniform it says a surface is illegal.  I need to scale only the y direction.
innovatenate
Autodesk Support
Autodesk Support
If I unstitch the body and delete some faces (see the Patch environment), I'm able to perform the non-uniform scale.
You could use the thicken command afterward to rebuild the solid.
Check out the attached file for reference.
I hope that helps!
Nathan Chandler
Principal Specialist
SlawsonEngineering
Which surfaces did you delete?
innovatenate
Autodesk Support
Autodesk Support
There's a screencast uploading below that should help to clarify which faces were deleted.
http://autode.sk/2gzaBPQ
I hope that helps!
Nathan Chandler
SlawsonEngineering
That explains it very well.  Thank you very much.  That was so helpful!
