- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I have a model that I was given from someone else for a project, it is a STEP File, and it is exactly what I need for the project I am currently working on.
However, it is the wrong dimensions when loaded into Fusion 360
As an example, the design of this vehicle chassis is 3,577mm long and in Fusion is is 1,460mm long
So I thought no worries, I'll make it 2.45x bigger and it ends up still a few mm off, I think first time was 3,578.something
Now for what I need, these measurements need to be EXACT unfortunately, is there a way to click on it and manually set the length, width, and height by typing in the exact millimetre dimensions rather than the scale tool?
I've found a number of topics like this one however they do not help, they still involve using the scale tool to get it fairly close.
For reference, this model will be used to help manufacture Electric Vehicle Conversion Kits for a popular vehicle, as such I need the diagrams and sizes to be bang on for the vehicle engineer to look over in principle and run his own simulations on, turns out he uses 360 as well, hence why I have moved over to 360 as he can run his simulations in 360 which is nice.
