Scale Sketch with body
marc5KGCS
marc5KGCS
I want to scale a body, but i need my sketch to do the same an the same time. Is there a way to do this?
davebYYPCU
If you followed normal convention, scale the sketch, the body will follow.
Might help....
LeonardoBN
Hi Marc. How is this object?
If you really want to scale a sketch from a body, you have to make two sketches: the first for body generation, and the second, based on that geometry and with all dimensions based on that shape.
I can conceive this for basic shapes, but I thinks it will fail for more complex bodies.
Leonardo Brunelli do Nascimento
Chemical Engineer
marc5KGCS
Well... here's the body, but the sketch that i want to scale with the body is not the sketch from the body itself. I made a few other sketches that i want to use as a tool path inside the Manufacture workspace... but i might just redraw them, and be done with.
davebYYPCU
Project your body to a sketch, move the timeline in front of that sketch, scale the body, restore the timeline.
Might help...
marc5KGCS
Your the Man!! I did not think of that! Thanks!
