Scale Sketch in One Axis Only
MaxHugen
MaxHugen
While searching I've found references to scaling in one axis for other CAD products, but not for F360 so far.  I have a sketch on an XZ plane, which I need to scale only in the Z axis:
Is there a way to do this in F360?
jeff_strater
no, there is no non-uniform scale in sketch.  Usually, one does this using dimensions.  In this case, it would be some vertical dimensions on the fit points
Jeff Strater
Engineering Director
MaxHugen
OK, thanks Jeff. I'll work something out.
davebYYPCU
Extrude a body, scale non uniform works on the body, project the new outline to a new sketch.
Might help.....
MaxHugen
Hi Dave, I looked at Extrude, but not sure how you're using it.
I ended up using a plane at an angle that I calculated, and projecting onto it.  Worked fine, but a bit fussy.
Cheers, Max
davebYYPCU
Checking back I see that you don't have the blue shading, so extrude would not work out, unless it was a surface body.
Might help...
