Scale by editing dimension
etfrench
Mentor Mentor
etfrench
Does this actually work?  If so what's the secret sauce?
From 'What's New':
"Good news everyone! This option was talked about in this post awhile back, and we’re glad to share it with you. Now when you create multiple sketch entities in your sketch, you can affect the scale of entire sketch by just editing the very first dimension that you have created. This should make it easier to scale/edit the scale of sketches earlier in the design workflow, without needing to dimension every single sketch entity separately."
ETFrench
jeff_strater
@etfrench - there is an option for this.  This is not my favorite enhancement, FWIW, but if you want to use it, you need to turn on the option:
screencast:
Jeff Strater
Engineering Director
jeff_strater
oh, and it only works if you have one and only one dimension.
Jeff Strater
etfrench
Whew, I was afraid it would automatically rescale the sketch whenever the first dimension was edited.  I think I can guarantee that it won't be turned on on my computer 😀
ETFrench
chrisplyler
I wouldn't use it either, because I constrain as I go. I've never once drawn an entire complex sketch and then started adding dimensions.
But I've seen enough threads on this forum of people who have completely unconstrained sketches and lamenting that it's too hard to get everything scaled right, so maybe this will help them.
