Saved image not updating
So, one time while I was designing I was doing a section analysis and saved the file.  Now every time I save the file the image in my save folder is the same section analysis picture.
  I've tried saving as a different name, to a different location and deleting all the current files, I even tried giving it a different name and saving it to a flash and  opening and re-saving and the same **** picture shows up.    What the hell, why doesnt it update?
dsouzasujay
Hi @Anonymous ,
Can you please add more details, After created a section analysis and saving the file, are you referencing the data panel thumbnail image that is not updating?
Did you Hide/Delete the created section analysis before next save?
If you can record the problem in a screencast/video, that will help us to know more details.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
