Save Stock issues
Save Stock issues
mjames
Message 1 of 9
Save Stock issues
mjames
I find that when I Save Stock after a simulate, then reopen that .stl file, the model is in millimeters instead of my default inches, and the scale is 10X what it should be.
Are these bugs - or features?
Mike
Replies (8)
Message 2 of 9
paul.clauss
Hi @mjames
Thanks for posting! This is a known issue involving the unit-less nature of .STL format files. It has been logged with our development team and they are working to provide a solution!
A workaround does exist though! Instead of uploading the mesh and opening as a design through the data panel, using the "Insert Mesh" function in Fusion 360 will allow your saved stock files to be import correctly. I have illustrated this in the screencast below:
Please let me know if you have any other questions!
Paul Clauss
Product Support Specialist
Message 3 of 9
mjames
Hi Paul,
I am using the Insert Mesh command, but when I right click on the Mesh in the Browser, I don't get a Mesh to BRep option.
Any advice?
Message 4 of 9
paul.clauss
Hi @mjames,
Thank you for bringing this to my attention! I was able to reproduce the issue with "Mesh to Brep" not showing up when inserting a mesh into a new file.
Firstly, make sure that the Mesh workspace preview is enabled in Fusion 360. To do so, click on your name in the upper right hand corner of Fusion and select "Preferences." Navigate to "Preview" on the table of contents on the left hand side and click the check to enable the Mesh workspace preview.
I also found a strange issue in which the "Mesh to Brep" option does not appear if the mesh is inserted using the "Insert Mesh" tool unless the mesh is inserted into an uploaded .STL file. I have illustrated this in the screencast below, which also contains a potential solution for you:
Hopefully this helps! Please let me know if you have any other questions.
Paul Clauss
Message 5 of 9
mjames
Hi Paul,
I'm not getting the same results as you.
I checked the Mesh Workspace Preview, then opened a saved STL file. When I right click on the mesh in the browser, I get a Convert function (which is new) but no Mesh to Brep function.
Also, units are in MM although the default is inches for everything.
Mike
Message 6 of 9
paul.clauss
Hi @mjames,
Are you in the Mesh workspace when right clicking the mesh body? When I right click in the Mesh workspace I am not given the option to "Convert to Brep" in the Mesh workspace, but am in the Model workspace. Please give this a try and let me know how it goes!
Paul Clauss
Message 7 of 9
mjames
Hi Paul,
It appears that Sculpt and Mesh do not show the Mesh to Brep function, however Model does show it.
After using the function, the model is 10X scale, so we're kind of back where we started with the Insert Mesh.
Mike
Message 8 of 9
paul.clauss
Hi @mjames
Glad we made some progress! To eliminate the scaling, you will need to insert the same mesh file into the design you started. This will allow the mesh to come in scaled properly - please refer to the screencast in my second post from last Friday for details on this strange behavior.
Another option could be to use the Modify > Scale tool to correct the sizing of your model. I have shown this in the screencast below:
Paul Clauss
Message 9 of 9
mjames
Thanks Paul. Hopefully this will be fixed eventually.
