Save Custom Background Color to the Default Options
scoot28
scoot28
Hey, I was wondering if it's possible to add a custom background color (15,25,5) to the default color options in AutoCad LT 2015 ?
Reason I ask is I do normal Autocad work with the custom background color of 15,25,5 but often I need to change the background color to white to create jpg images directly from Autocad. But once I'm done with that I need to change the color by back to 15,25,5 for normal work.  So in the option menu I would like to see my custom color where you see the default colors of red, green, yellow, etc.
Is this possible ?
Scott
AutoCad LT 2015
James.Youmatz
Autodesk Support
Autodesk Support
Hi @scoot28,
Welcome to the Fusion 360 Community!
I just wanted to point out that this forum is intended for Fusion 360 support - not AutoCAD. The best forum to reach out for those related questions is here.
Off this note - try using this article here to add a custom background in AutoCAD 2015.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
scoot28
Ok.. thanks James
AutoCad LT 2015
