- Mute
- Permalink
- Report
I uncovered a problem when I changed two dimensions on a sketch. Summarizing the issue, this sketch drove a revolve, which was combined with a cylinder. That worked. Moving forward in the timeline, a third body was used to cut this combined body. That did not work right... the cut was made, but the body was split back into the two original bodies (both were cut, and also separated).
So I decided to use Save As to save this broken version and planned to abandon the changes to keep my previous version. Fusion saved all my changes, closed the working file and made a new file. This is so wrong in so many ways as a program behavior. It is not helpful. It should have left the unsaved edited file open and made a new file like I wanted. Now I can't revert and try something different, I have two broken files.
I am attaching this broken version so you can look at it and find out why the edit sketch broke the second combine operation. But I want you to know I am not at all happy with the file management issue either.
