Running FEA for a robotic claw, and only one of the jaws is closing
581876
581876
link to file https://a360.co/48za1gZ
TheCADWhisperer
@581876
Can you explain what you would like to know from this analysis?
If you are doing Static Analysis - there should be no motion.
I see anomalies in the geometry.
For example, this interference of two bodies.
I saw other geometry anomalies that might increase the complexity of meshing, and the entire assembly has too much detailed geometry.
The goal is to see where the weak spots are in the claw when grabbing stuff.
TheCADWhisperer
@581876
You need to idealize the model for the purpose of analysis - your assembly is far too complex.
I would analyze individual components or sub-assemblies with reduced detail.
