Rule Fillet command missing with latest Fusion360 Update
dali77
dali77
I'm sure I'm missing something obvious but I have just fired up the updated Fusion360 and seem to have lost the Create > Rule Fillet command? Is this as expected?
Yep I was missing something. The Design didn't have Capture Design HIstory Enabled.
Make Anything
jeff_strater
Yes, that's correct.  Rule Fillet is only available in a Parametric (history) design.
That command really doesn't make sense in a Direct Modeling design - the whole power of Rule Fillet is that it updates more robustly and will handle new edges added to a feature, etc.  Since Direct Modeling features don't update, this feature is not implemented there.
Jeff Strater (Fusion Development)
Jeff Strater
Engineering Director
colin.smith
Hi @dali77
Just to be clear, when you look under Fillet in the Modify drop down you don't see Rule Fillet below it?
Can you post a screen shot of what you see there?
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
colin.smith
Ah, I missed the part where you stated it was Non-history.  I should have more coffee before reading these. Smiley Embarassed
Colin Smith
Sr. Product Manager
SketchBook
dca1978
Sorry to revive an old thread, but it seems that now the rule fillet command is indeed gone from the latest version. I can find it neither on the modify menu nor by calling it with the design shortcuts pop up menu.
Is there an alternative for it?
jeff_strater
still there, just merged with the Fillet command.  You can select it in the dropdown for Fillet:
Jeff Strater
dca1978
Got it. Thanks a lot Jeff!
