Rounding bug
Rounding bug
etfrench
Mentor Mentor
Message 1 of 8
Rounding bug
etfrench
The video shows a simple move with three decimal place accuracy, but the dimension after the move requires 9 decimal places.  While one could argue that anything after 5 decimal places is irrelevant, Fusion 360 has trouble with intersecting lines and faces at small angles, mirroring closed geometry doesn't always create closed geometry, patterns may fail because of rounding errors (At least, that's why I think they're failing Smiley Tongue)
ETFrench
Replies (7)
Message 2 of 8
kate.raskauskas
Hi @etfrench,
Thanks for attaching your file- I opened it and followed the steps in your screencast, but wasn't able to replicate the decimal craziness. Does this happen with other sketches in the same design or with sketches in other designs, or in this sketch only? Also, do you have the Sketch preview turned on?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
Message 3 of 8
etfrench
Attached is the file before the move.  The bug may be related to moving back and forth between metric and imperial.  Sketch and Mesh are turned on in Preview preferences.
ETFrench
Message 4 of 8
kate.raskauskas
Thanks for the additional file, @etfrench. I'm still not able to reproduce it on this one either. Can you try turning off sketch in preview and see if that helps at all?
Also, is this the only sketch this is happening to, or do other sketches have a ton of decimals too?
Kate Raskauskas
Message 5 of 8
etfrench
All sketches have tons (9 to be precise) of decimals when the maximum precision is set in Preferences Smiley Surprised
Turning of Sketch Preview doesn't alter the behaviour.
ETFrench
Message 6 of 8
etfrench
Have you been able to repro this bug with precision set to max?
ETFrench
Message 7 of 8
kate.raskauskas
@etfrench,
Yes, I was able to reproduce it-- and I found a way to fix it! It looks like the angles for top lines in the sketch were veeeery slightly off. When I set the angle to 90, the sketch behaved like it should. (I had to set the angle precision to max as well to catch it)
Kate Raskauskas
Message 8 of 8
etfrench
Interesting. Little errors are not very obvious in the UI.
ETFrench
