Rough surface and split perimeter
brick1343
Message 1 of 14
brick1343
I can't get this to print correctly.  The perimeter oval is uneven in places and has gaps between walls (see upper right and lower left of image).   Also the surface of the dancers figure is rough.  I'm printing with PLA on an Ender 3 V2 Neo.
Replies (13)
Message 2 of 14
etfrench
There are too many details less than .5mm thick.  It's unlikely to print well on an fdm printer.
p.s. Tuning your printer may help: https://ellis3dp.com/Print-Tuning-Guide/
ETFrench
Message 3 of 14
g-andresen
What nozzle size are you working with?
With 0.25mm it should work
Günther
Message 4 of 14
wersy
There are even a detail of 0.15 mm.
The smallest detail should be at least 2 times as large as the nozzle diameter.
That means if you have a 0.4 mm nozzle the details should be not smaller than 0.8 mm.
Message 5 of 14
brick1343
I'm using a .4 mm nozzle.
Message 6 of 14
brick1343
The outside oval is 1.29mm wide so why does it split?   I tried changing it to 1.24 so it's an even multiple of .4 but it still splits.
Message 7 of 14
etfrench
That's in your printer.  Have you gone through the calibration process linked earlier?
ETFrench
Message 8 of 14
wersy
Without pictures of the print it is impossible to make a statement. I can only guess that you printed with under-extrusion.
But these are problems that have nothing to do with Fusion, unless you use the Fusion slicer.
I would advise you to contact one of the many printer forums.
Message 9 of 14
brick1343
Hi Betreff,
A picture of the print is attached to my original post.
Message 10 of 14
brick1343
Everything else that I've printed has come out fine. It's just this one design.  However, I'll try going through the calibration.
Message 11 of 14
wersy
If this is to be the print, the image is far too poor to see print details.
Message 12 of 14
brick1343
Message 13 of 14
wersy
Try with setting "fill gaps".
Message 14 of 14
brick1343
I got it working.  The main issue was the Y axis belt was loose.  I also followed etfrench's calibration instructions.
Thanks for all the help.  I'm new to 3d printing and still have a lot to learn.
