rotational joints
rotational joints
kevinfirchow
Message 1 of 10
rotational joints
kevinfirchow
Ive drawn a spindle and king pin assembly, where spindle rotates around the king pin.  I have now added a bracket that bolts to the spindle. My struggle is fixing the bracket to rotate with the spindle, while keeping them separate components.  I have tried using the "as built" joint tool and adding a rigid joint but I still get the result shown below.  Any tips is appreciated
(view in My Videos)
Replies (9)
Message 2 of 10
davebYYPCU
Separate Components. (Tick)
Rigid Joint - Plate to the Spindle, (not yet.)
Looks like the plate is fixed somehow,
needs to be free to Move before you make the Rigid Joint - Plate to the Spindle.
Might help...
Message 3 of 10
jhackney1972
Please attach you model in order to get the best answer.
John Hackney, Retired
Message 4 of 10
kevinfirchow
attached is the STL
Message 5 of 10
jhackney1972
A STL of the model will not work.  Open your model, select the Export command from the File menu and save your model as a F3D or F3Z to your hard drive.  Attach that to a reply post.  If it is a F3Z file, you may have to ZIP it to allow it to attach.
Message 6 of 10
kevinfirchow
sorry about that
Message 7 of 10
jhackney1972
Attached is your model with the configuration I think you want.  Let me know if not.
Message 8 of 10
kevinfirchow
this is it, might i ask what you did to achieve this
Message 9 of 10
jhackney1972
You were not far off. The main thing was that you had the wrong component "Ground to Parent". The video will explain.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
(view in My Videos)
Message 10 of 10
kevinfirchow
Couldnt have asked for a better response! thankyou for eeverything.
