Rotating view from point of click?
Message 1 of 15
Hi Again,
Is there a way to make it so that when you spin/rotate a model, that you're actually using the point that you click, as the point of rotation, much like is SolidWorks default behavior?
Currently, it rotates around an automatically predetermined green point - which I assume is the center of volume.
But, when I zoom into something, say the tip of a pencil, for example, and I want to get a closer view, I'd like to spin around the now zoomed in upon pencil tip, or other feature I'd like to view. Instead, I have to deal with the now off-page point predetermined point of rotation to work with, and will end up having my entire model flip out when I make what I would consider a 'normal' movement. Which means now I have to zoom out, and start over spinning the model again to get a decent view.
Is there a way to do this?
-Alex
Replies (14)
Message 2 of 15
Beyondforce
Hi @Anonymous,
You need to click on the Shift key and the middle mouse.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 15
That's what I'm doing - though it's just the middle mouse button with the SolidWorks configuration, however that doesn't fix the problem that I was describing, it simply gives rotation.
Message 4 of 15
Beyondforce
Every time you want to change the focus on a different spot, you need to re-click the Shift + mouse middle button.
Ben Korez
| YouTube
Message 5 of 15
Beyondforce
If it's annoying you, then you better get yourself something like this:
http://www.3dconnexion.eu/products/spacemouse/spacemousewireless.html
Ben Korez
| YouTube
Message 6 of 15
Beyondforce
Another thing you can do, is Right click anywhere and Set Orbit Center.
Ben Korez
| YouTube
Message 7 of 15
I think the problem stems from the shape of the model, assuming you're actually trying to rotate around the point of a pencil. When using the "Solidworks" rotation setting and clicking the middle mouse button, it looks like Fusion is trying to snap the rotation point to the nearest vertex or edge. If you don't have the cursor exactly over the point of the pencil, the rotation point snaps to something off screen.
On non-pointy models, the rotation point is set fairly close to the point I clicked.
Message 8 of 15
Thanks for the work arounds.
It still seems extremely strange that you have to forcibly change the orbit of rotation, rather than it happening on each middle click automatically.
Message 9 of 15
mmilleratticus
I too, more than once, would like to precisely rotate my work to create a home view.  As a design evolves I paint myself into a corner with feature placement.  The easiest thing to do is create a new home view to aid visualization...but alas it is not possible.
Message 10 of 15
chrisplyler
You can't change the Home view, but you CAN create saved views and return to them whenever you want.
Message 11 of 15
mmilleratticus
Yeah, I know that.  But if I cannot create a precise view, what value does it have to save it?  The root question is to create a precise view.  Is there a way to create a view off of a construction plane?
Message 12 of 15
chrisplyler
Oops! I was wrong. You CAN change the Home view...
And you can set up a constructed plane, use the Look-at tool to orient on it, and then either set the Home view OR create a Named view in the Project Browser.
Message 13 of 15
mmilleratticus
Boom...Amazing how talking through things helps eh?
Thanks!
Message 14 of 15
chrisplyler
Thanks!
Amazing how talking through things exploring the user interface helps eh?
Message 15 of 15
design
Had this exact same problem recently and what worked for me was to double click with the middle mouse button on the point about which I want to rotate my view.
