Rotating point to point
elofusion
elofusion
I have a question if its possible to rotate point to point in fusion 360? or to rotate to a axis?
Thanks!
lichtzeichenanlage
Not sure what you are exactly having in mind, but perhaps you are looking for the revolve command
laughingcreek
No, not directly with the move command.  you can measure the angle between objects and rotate by that, but that raises the possibility of modeling errors.  For instance I wouldn't use that technique to put faces together.  The align command can get you there sometimes also.  if you want you could post an example
lichtzeichenanlage
It would be good to have a less abstract example or even better a export of your current design or a link to it. Are you're working in the  model environment? Could you use construction planes or joints to solve your problem?
jodom4
Hey elofusion,
It sounds like you're describing the way rotate works in AutoCAD with a reference, or the way it works in Rhino as point-to-point rotate. I don't know if there's any intention of making this a feature, but it's a good one for the IdeaStation.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
KhrisKhad
A possible workaround is to use Align to match up the planes, then move it into place.
