Rotate current view 90 deg
Message 1 of 12
Is it any way, I mean shortcut to rotate current view 90.
I can use arrows at the cube at the right upper corner, but this works only in "standard" views.
When I use "LOOK AT" and then select face - not always view is rotated as I want it.  Sometimes would be nice and easier to rotate it for 90 deg CW or CCW. Or maybe there is an option to set rotation angle?
Marek
Replies (11)
Message 2 of 12
Mike.Grau
Hi @Anonymous,
Thank you for asking about that.
Currently, we do not have a Keyboard Shortcut for Rotating the view by 90°.
I think this is a great Idea and you should post this in our Idea Station with the link here
I look forward to see your post in the Idea station.
Please, keep me updated.
Thanks you,
Message 3 of 12
Mike,
I just posted this as a idea,
Rotate current view 90 deg or desired angle
Hope it will be added in future
Marek
Message 4 of 12
Mike.Grau
Hi @Anonymous,
Thank you for your post in the Idea station.
I have voted for it. That´s great.
Thank you,
Message 5 of 12
laughingcreek
If you select "Constrained Orbit" at the bottom" , then left click over the faint circle that appears, you can spin the current view CW or CCW.
Not the shortcut you were looking for, but is that what you were looking to do?
Message 6 of 12
This doesn't work unless the view is TOP, SIDE or BOTTOM. Does it?
I have the same wish since many of the sketches I work with not is aligned with the world map. A bit annoying drawing in e.g. 90 degree angle.
Message 7 of 12
laughingcreek
It doesn't matter what the current view diection is.  Using the circle that shows up after selecting "constrained orbit" from the bottom of the screen will spin the current view CW or CCW. (you have to hover diretly over the circle till the icon changes)
Message 8 of 12
I can see that, but then I have to rotate it 90 degrees in free hand right? I just wish for the ability to rotate it like if in world map coordinates.
Message 9 of 12
HughesTooling
As a workaround, you have the option to set the current view to the Front View while sketching or after using Look At, after closing the sketch just reset.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 10 of 12
Yes, it works in case when normal vie is set somehow aligned with the geometry, but in some cases, as I have showed at the very beginning to looks like normal view orientation is random or aligned to something I do not know to.
Message 11 of 12
formsR28H6
I cannot believe that so many years later, this cannot be done.
I have sketches on inclined planes and firstly as soon as I edit that sketch, F360 rotates the camera view by 90 degrees even though the "Auto Look at Sketch" is disabled in preferences.
Why can't there just be a keyboard shortcut, or option to rotate the camera view by 90 degrees no matter whether or not the current camera angle is perpendicular to any of the 3 origin axes.
Now you can ONLY rotate the view when perpendicular to these 3 axes, this is very frustrating, and I have been trying to fix this for the last hour.
The most annoying one is when editing and sketch where it rotates the camera when selecting "Look At" when I dont want it to, and there seems no way to stop this behaviour.
an enhancement would be to add a preference to Auto Look at Sketch that does not rotate the camera, but opens the sketch at whatever angle it is tilted at X-Y ?
Message 12 of 12
formsR28H6
This work for me as an add-in to rotate the camera view at any angle and not just when you are square on with the XYZ planes.
Interested if it works for others and solves the problem ?
