Rolling pin constraint
Message 1 of 1
I would like to simulate static stress on a piece in which one of the constraints is hole holded by a pin. The piece should be able to rotate tangentially around the pin and at the same time the pin should be able to slide on one direction. However the pin constraint only allows rotations and the fixed constraint only allows translations and no rotations and I would need a combination of the two: allowing tangential rotation and translation in one direction, effectively modeling a rolling pin constraint
Replies (0)
