Message 1 of 22
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The behavior of a rigid joint differs depending on how the joint was created. I see this as an anomaly at best, or a bug at worst, until someone can explain the logic between the joint behavior differences. Using Joint (Rigid behavior) in case 1, and As Built Joint (Rigid behavior) in case 2. When one of the components in each case is resized, the joint relationship is maintained in case 1, but the relationship not maintained in case 2. Both joint commands are specified as "Rigid". After the resizing of one on the components, the joint is indeed rigid in both cases, but the relationship of the faces that are joined together is different. Why is this? I do not find this intuitive. Until explained I view it as illogical as well - or even a bug. Help me out here. Why this behavior difference?
I have documented the process used to demonstrate the anomalous behavior in the referenced screencast.
<iframe width="640" height="650" src="https://screencast.autodesk.com/Embed/Timeline/418a2e7e-4564-460e-905e-c2b727194bda" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
David
