Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Revolve problem
2 REPLIES 2
jruetenik
336 Views, 2 Replies
Revolve problem
I ran into a weird problem trying to revolve a profile around an axis. It seems to revolve correctly on one end of the body, but not the opposite end. I separated the two bodies and placed them into a new design and made a screencast. It was repeatable. I can't find where I did anything wrong. Using Windows 10, Fusion 360 version 2.0.5688
2 REPLIES 2
g-andresen
in reply to: jruetenik
try this:
option > Join/New Body ...option > Join/New Body ...
Sorry, it´s another behavior:
plane not alignedplane not aligned
The plane is not aligned with the axis.
günther
jruetenik
in reply to: g-andresen
Thanks for the tip...a profile does need to align with axis to revolve correctly...why it revolved correctly on one side I haven't a clue...a more elegant solution was to create a sketch plane perpendicular to the profile plane and draw an arc using cylinder center and closest point of profile as the start, then do a cut sweep along that arc.
