I'm trying to use revolve on a cylindrical shapes hydrant/canister, call it what you will. But although the sketch is fully closed, and created using line and splines in model mode, it seems the body created with the revolve has separate pieces. This is no good as I need to export to external application later on and that piece that has been revolved needs to be one combined model for texturing purposes. I could fix it later on but would probably take me longer than modelling it from scratch with poly modelling methods.
Below is image of what I'm attempting. File can also be found here (http://a360.co/2fRfSn1)
\When I try combine, it all of a sudden acts like one object.
Is this normal behaviour or is there another way?
