revolve around 2 perpendicular axis simultaneously
Hello, I am having a problem trying to revolve a part on a swivel eyebolt in 2 perpendicular planes (see screencast). I am using the as-built joint command, it seems to me you have to attach the eye part rigidly to the body and then rotate the body, however since it is now rigid with the body it cannot rotate in any other plane, There may be another way or command to allow this I hope.
The part is available on Mcmaster: https://www.mcmaster.com/#2994t59/=1c31uye
Thanks.
Jacques
lichtzeichenanlage
Unfortunately the screen cast is missing. And perhaps you can export and attach or share your project.
davebYYPCU
Four components, four joints, from McMaster pic, as built is not the problem, easier that way
Revolve the inner base around the bolt.
Revolve the "Axle" and the Eye, (one side)
Rigid the Axle and the inner base. Or visa versa.
One Joint per component.  Rigid the bolt to ........
laughingcreek
no screen cast.  if you put the link in the "insert screencast" box at the bottom, you have to hit preview, then insert, then post, or it won't show up.
Yup, got it. Thank you.
OK, thanks, I will know for the next time.
