- Mute
- Permalink
- Report
Let's say I have a house key whose hole is not round but a trapezoid. I want to put that key over a round pin or cylinder and have the key rotate about that pin. I can't seem to make that happen with the revolute joint (or any other joint). It always snaps to one of the edges of the trapezoid so that the pin appears to be half inside the trapezoidal hole and half inside the solid key. If I change the key to have a cylindrical hole I can make it work.
In reality the key would sloppily rotate about the pin as each side of the trapezoid moves around and hits the pin - this is fine - but if Fusion just displays the pin in the center of the trapezoid OR picks one edge of the trapezoid and rotates there I am fine with it as well.
Is there a way to create a revolute joint between a cylinder and a non-cylindrical shape?
-Tom
