reverse normal
reverse normal
laughingcreek
Mentor Mentor
reverse normal
laughingcreek
How do I reverse the normals of a T-spline, and/or the resultant Brep surface while in parametic mode?
jeff_strater
Unfortunately, this is not yet implemented in parametric mode. It is high on our priority list, though.
In what case is this causing you problems? Where do you find yourself needing to flip the normal? Most times, if you end up with a closed region, and Stitch surfaces together, you will end up with a valid solid.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
