Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am a little stuck on how to proceed and could use some suggestions. I have a fanblade (missing a blade) that I laser scanned and I would like to reverse engineer a model of it so I can build molds to reproduce the part.
The process so far:
1. Laser scan existing part.
2. Cleaned the STL file using Autodesk Memento
3. Exported it as a obj quad mesh.
4. Imported into Fusion360 in sculpting
5. Convert quad mesh to Tspline
6. get sections from Tspline loft new surfaces
This is where I am looking for ideas....
How can I extend the loft to finish off the blade. or is there a better way to get there.
some pics and the model.....
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Engineer, Maker
