resize inserted dfx
resize inserted dfx
tmodcustoms
resize inserted dfx
tmodcustoms
is there a way to resize a dxf that is inserted. I fell like I should be able to scale it down but i dont have the magic touch. .
http://a360.co/20Sy4MM
HughesTooling
You can not scale in sketch mode. You can select a sketch in the browser and scale it but if you then edit the sketch you will roll the time to before the scale so editing of the sketch will be without the scale. So you can scale a sketch down then extrude and get a scaled down body but you can't actually scale the sketch.
Mark
Mark Hughes
Owner, Hughes Tooling
