Bug on extruding modified sketches
Another issue that i always have is that, when i want to try to add an element on a sketch, which is extrued, the extrution feature doesn't allow me to select it. I need to delete the extrution feacture and put a new again with the selected sketchs.
michallach81
Just hols shift and pick what you need it will add that to current selection.
Michał
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
HughesTooling
There is an odd bug where you can add one profile to a selection without holding the Ctrl key down to add more press and hold Ctrl. The only time you can't add a profile is if it's on a different plane, hard to tell if that might be what.s wrong in your example.
Here's a screencast adding one profile to a selection and shows that add a profile on a different plane fails.
Mark
Mark Hughes
Owner, Hughes Tooling
TrippyLighting
I've already rported that odd bug, which I believe has been intruduced in a recent update. Can;t foind the thread at the moment.
It's rather an inconsistenct that makes it a littel hard to understand the UI.
@Anonymous
having to press and hold the Ctrl key (or was it the Shift key ) in order to be ale to add new objects to an exoisting selectionworks broadly acroiss the toolsets in Fusion 360.
jmunkki5ZDPV
Control on Windows, Command on Mac. However, if you select or deselect a profile by accident, you need to move the mouse pointer outside the outline in order to be able to select or deselect it again. I posted a topic about this yesterday. If you don't move the mouse, the UI will not work (even if you hold down ctrl/cmd).
TrippyLighting
That actually is a bug and it has also been recorded, so I am hopefulthat it will be fixed soon.
