Repurpose Sketch from Previous Model
I would like to start a new 3D model but using a sketch from a previous design.  Is there a way to import a sketch?
DDMFGCOINC
Save your sketch as a DXF and Insert the DXF on the plane of your choice.
Thank you!  Can't get much easier than that.  Very much appreciated.
laughingcreek
Plain old copy and paste works fine to.  You do have to start a sketch before you paste.  And also be carful of selecting sketch entities on different sketches, because everything will get pasted onto one sketch, and the results can be in predictable.  (that's the second part of screen cast).
This is great! Thank you for taking the time to create the video example. Very helpful.
TrippyLighting
@Anonymous if @laughingcreek's pos solved your problem, please mark his answers the solution.
Done!
