Replace linked component?
alanautodeskN2HS2
Observer Observer
Message 1 of 8
alanautodeskN2HS2
Observer
Observer
I uploaded a f3d which unfortunately brought along its own copies of the linked components.
I would like to change these links to point to our "parts" project where we keep all of the parts so that as they are updated, the main project will be as well.
How can I do this?
Thanks in advance,
Alan
Replies (7)
Message 2 of 8
jeff_strater
unfortunately, Replace Component is not yet supported by Fusion.  The only solution is to Delete or Remove the Insert Component feature, and re-insert the design you want to use instead.
Jeff Strater
Engineering Director
Message 3 of 8
yourout
Is there a plan to someday add a "Replace" function?
Message 4 of 8
jeff_strater
Yes.  That work is already in progress.  Of course I cannot predict an update when it will be released, but I have seen it working with my own eyes, so hang on just a bit longer...
Set your expectations correctly for this, however.  If you make a replacement component using the original as the starting point, we think that most downstream references (joints, projections into a sketch, etc) will survive, but if you replace a component with a completely unrelated component, expect to have to edit joints, etc to refer to the new geometry.
Jeff Strater
Message 5 of 8
yourout
Understood.....with great power comes great responsibility so they say. 😊
Message 6 of 8
helfenj
Hi @alanautodeskN2HS2,
I can be more specific, we have replace for external components coming later this month with the January release.
You will be able to right click an external component in the browser and choose to replace the single instance or choose to Replace All Instances. This will only be available for external components, but will automate the process Jeff mentioned above.
There may be joint repair required depending on what the component is being replaced with, but the amount of time this saves when simply swapping out hardware can be significant.
Watch for the Jan release and let us know what you think. Hope it smooths your workflows.
John
Message 7 of 8
yourout
I like the new replace feature.....thanks!
Message 8 of 8
helfenj
@yourout You're quite welcome. Glad you like it.
