Repeat irregular holes at points
AntiHeadshot
AntiHeadshot
Is there a way to repeat shaped holes on points?
I want the 8 circles on the right to be the shape below them, without repeating the shape 8 times. These circles will be holes, so if there is a tool to repeat features or similar at points it would do the job too.
Is there a way to do this?
etfrench
The Paste command remains active, so you only need to do one copy and eight pastes with Move|Point to Point.  I'd delete the target circles first.  The target circles are not the same diameter, so you should fully dimension the original shape before copying.
ETFrench
