Rendering Mesh...?
Rendering Mesh...?
rushabhthakkar_910
Advisor Advisor
Rendering Mesh...?
rushabhthakkar_910
How do you Render a Mesh File...?
Actually I tried Rendering some Mesh files Downloaded from Net...
And the whole Design was Getting Selected together...
So, I had to use the Option of Mesh to B-Rep..
And if it exceeded some specified faces, it was Aborted and I had to Reduce the Mesh and then Proceed to the Conversion.
And then all the Small Faces were getting Selected Individually... And to Render it, I had to Individually select each and Render them...
So, Is there any easy way to Render Mesh...?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
TrippyLighting
Why would you use Fusion 360 to render a mesh? Use Blender 😉
rushabhthakkar_910
Thank You so much @TrippyLighting for the Suggestion...
I'll Surely have a look at Blender...
Thanks and Regards,
Rushabh Thakkar.
