Rendering Locally
Rendering Locally
mda
Rendering Locally
mda
This is a bit of a noob question but one I haven't found the answer to in the forums or knowledge center.  I'm pressed for time here so any help asap is appreciated.  I need to produce some renders with custom sizes and transparent backgrounds.  As I know it, this can only be done using the local render option.  I've set everything up and clicked render to produce the local renders and I've now got the below image in my rendering gallery.  My questions are:
1. Once these image captures are made, am I able to continue working on this or other models without it impacting the renders.  I usually don't use local render because in-canvas render is more convenient to my needs.  I know that you can't adjust anything when using in-canvas render or the render process restarts which is why I'm asking this question with regards to local rendering.
2. In the image the thumbnail on the far right has a green bar across it which when hovered over says the estimated time for completion is 4 hours.  This status doesn't seem to be changing.  Does this update to reflect remaining time in a real sense or will it just say 4 hours until it finishes?  My concern here is that I need these renders by the end of the day and if there is some disruption with the render processing and I have no way to see that, I'm going to be screwed.
3. The thumbnails to the left in the image below, are these showing a clock face icon because they are que'd and haven't yet started processing?
Sorry for such simple questions to the forum but I can't find my answers anywhere else and my time is running short.  Is it just me or is the UI for local rendering a bit less than intuitive or insightful?
lichtzeichenanlage
Duplicate post. Follow discussion here.
mda
When I click on your link to the discussion you're intending to share, it takes me right back to my original post.  Is it possible you pasted the wrong URL into your link, or are you taking the Micky?  You've got me really confused.
