Rendering appearance issue
I am currently having an issue with the rendering of certain objects in fusion 360 no matter how many iterations. Is there a solution to this? as you can see the wheel and part of the front cone are not correctly rendered.
SaeedHamza
Normally this happens when 2 identical bodies are overlapping, so check if this is one body or two, one inside the other
Regards, Saeed
Saeed Hamza
Hey, However I cant seem to hide the interior part or delete it...
JamieGilchrist
hi 06julianf,
SaeedHamza is correct the overlapping faces don't render particularly well.  Can you offset the faces a timy amount <0.5mm?  this should solve the problem
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
SaeedHamza
try hiding it, right-click and hold and select it, then right-click again to view the menu and click hide
I don't recommend deleting it because it may cause problems in your timeline
Saeed Hamza
