- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have an issue with rendering, in that I normally have to render something 5 or 6 times to get the zoom level and model position correct on the rendered image, since I have no way of seeing how large the model will be on the render until it is complete. Is there a way to preview the size of the render to get the zoom level correct (i.e. not simply doing an in-canvas render, which doesn't show the image size)?
I've seen some solutions which talk about using "Named Views" - I use these but they still require multiple renders when setting them up in order to get the zoom and angle correct. Once set up they are fine.. until I change the render resolution and then I have to start again.
I am a former solidworks user, and the render preview showed the extent of the whole rendered image, allowing the model to be positioned correctly and the zoom level set prior to committing to a full render. Does a similar functionality exist in Fusion 360?
Thanks in advance,
Woody
