Removing gaps from solids
nmday3GBLC
Observer Observer
nmday3GBLC
Observer
Observer
Hello Fusioneers!
So, I've been having an interesting problem with a model that I downloaded from GrabCad as an .STP.  I've found a work around, but I suspect there's a better way to do this that as a relative newcomer to F360 I'm unaware of.
This is a model of a GT2 Timing Belt that I'm using as a tool body to create some fixtures for a project I'm working on.  The model is constructed as a series of segments that seem to have been stitched together, however there's a small gap in the middle of the link (one example circled below):
This causes artifacts when I use it with the combine tool to cut out slot to insert the end of the belt into.  Is there a good way to fix this model?  Or remove the artifacts quickly?  My work around is labor-intensive and I'm looking for a faster way to get this done...
Thanks!
-neil
TheCADWhisperer
With geometry this simple - I would remodel it from scratch rather than using someone else's rubbish in my design.
Should take less than five minutes.
Would you like for me to remodel it for you?
nmday3GBLC
Observer
Observer
Thanks for the quick reply, and for your kind offer!  That will be a good exercise for me to do, so I'll give it a swing and let you know if I have any questions...I really appreciate your help!
Best
-n
g-andresen
it´s not only the gap!
Create a new one and you have a clean construction that will save your nerves!
günther
Pradipio
Autodesk Support
Autodesk Support
Hi @nmday3GBLC ,
Thanks for posting on forum, here I did some Workaround with model and try to remove gaps by move/rotate faces.
here I have attached a screen cast video for you.
I hope this will helps to move ahead.
Please accept the solution if you get it done.
THANKS
Pradip Mistry
”Community
