Removing design version from a design project
Matthew0x
Matthew0x
it is my first post, I hope I didn't really miss any rules.
The question is theoretically simple, how does one remove a version from the versioning system tracker (v1, v2, v3...).
I have been working on a part for a device I build and I wanted to modify the offsets for parts that connect.
I first accidently created a new version that for some reason lacked like 60% of the parts I made (why? I don't know... a bug? missclick? aliens?)
Either way. I created a new version and there are 2 problems:
1. You can't really (?) save the new version if it's based on say version N-1 and you already created version N, unless you create a new design (why? This was my only option as the version N+1 based on N-1 was read-only, when N (that I couldn't remove) already existed)
2. You ... can't remove the old versions?
I don't use Fusion360 much, it's basically a hobby thing to me and I have spent half an hour or an hour trying to find this fundamental feature?
I might be missing something, but I don't want to remove the whole design. I just want to remove the specific version.
When I got into my version tracker, I can see the history of design versions, but all I can do is just to open them, which makes little sense if this were to be a true version tracker.
wmhazzard
You can't remove a version but you can open an older version, right click on the top level in the Browser and select save as latest.
stiller.design
If you want to delete the version history you can do that by: SAVE AS
then it will start at V1 again
hope that helps
Matthew0x
So effectively the only way to override the version is to restore an older one beforehand?
I will remember the next time, and it won't cost me much work at all this time, but if somebody selected a version N from the panel then spent an hour or two designing changes just to discover that they can't be saved...
it would be annoying, wouldn't it.
Nonetheless, your hack has worked. I will keep that trick in mind.
Thank you.
wmhazzard
It's not really a hack, it is the way Fusion is designed. If you opened a previous version with the intention of modifying it and saving it, you should see at the top of your screen a warning saying that a newer version exists prompting you to either update to the latest or save that version as the latest. Also, never work on Fusion for 2 hours without saving, that is a recipe for disaster.
