Removing appearance temporary
ari.hemila
ari.hemila
Hi guys, I have a component that I added several colors to the faces. Is there a way to temporarily disable the appearance ?
JHRendon
Unffornatuly you can't disable the appearance, but you can add another appearance. So if you want to re-assign the appearance you should select those faces and give the specific appearance to each face. If several faces have the same appearance I recommend you to make a "selection set"
Then when you want to give it the appearance you want you skip to select face by face, only the set you want the same appearance .
so you can select tha faces of each appearace, and when you want to give it the last appearance you skip the select face by face, only the set you want the same apperance .
Another tool you can use is "component color cycling toggle"
So it has a description what it does.
ari.hemila
Thank you for the quick answer. I think the solution for me is the  "component color cycling toggle", as my basic problems was to see sketch on a black surface.
JHRendon
Ooohh ok. I suppose you have a define sketch in a black surface
so another option could be change the enviroment
dark sky makes the define sketch white.
ari.hemila
Great,  that's another solution, thanks again 🙂
shahriarsifat1802164
Actually, you can not temporarily hide the apperance.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
g-andresen
try this workaound
günther
