Remove Panel from Toolbar
In the old UI, there is a way to remove panels from the toolbar that are not useful to you, such as Multi-Axis, Turning, Cutting, etc.
Old UI:
Remove panel.jpgNew UI:Remove panel new UI.jpg
Is this still possible in the new UI? If not, could we have this functionality added to the new UI? There is a large amount of extra space that these panels take up.
-Adam
jeff_strater
@Anonymous - unfortunately, as you've discovered, you can not remove entire panels in the new UI.  You bring up a good point, though, in the CAM environment, this could be more useful than, say, in the Design environment.  I will pass this along to the team.  @keqingsong , FYI.
Jeff Strater
Engineering Director
@keqingsong
Is there any news as to whether this or any other toolbar customization for the new UI is being worked on?
beav700
Please guys. Bring back the panel removal. I hate this UI everyday. I miss NX customization. I could change and drag Icons anyplace, have icons different sizes (some large, some small stacked on top of each other) and have then on all 4 sides of the screen (most on sides which is better with wide screens). Most of us would have tiny 50-80 icons all around the screen taking almost no room. It was a dream UI.
Fusion is horrible with wide screens. Huge Icons taking all the space on top and now no way to remove panels. Please at very least fix the panel removal. Please
