Help with creating useable components out of .skp file
Hi all. Need to have a model of a PeliCase 1600 for work. Unfortunately, the files that PeliCase gives out are laughable garbage. Simple rectangles....
Anyways, the only Pelicase 1600 model I was able to find that wasn't an .spk or DAE was behind a paywall (3Dcadbrowser)
So it looks as if I'm stuck with making the .spk work.
I'm able to create the components I need. Top, Bottom, Handle, Hinge piece
However - once I create those components... I have no way to align them and create joints as there are no faces. I also need to be able to slightly modify (some holes) in the body of the case.
I'm not sure of the best way to make this work well. If anybody can give some advice, it would be much appreciated. I'll attach some files and pictures.
*Looks like I can't attach a .spk - here is the link to where I got it. https://3dwarehouse.sketchup.com/model/94995584-16d8-4c2e-bf2c-f8ae5726310e/Unmodified-Pelican-1600-... *
Sydney
