remove material along an arc
Fueler
Fueler
Trying something new to me and stumbling.
In the attached file I have an arc. I need to remove everything from the edge to the arc.
Probably an better way but this is what came to mind at the moment
etfrench
You can do this with a plane by selecting the inner face of the rectangular opening then use the Split Body tool.  You can either remove or hide the unwanted side.
Or
Draw a boundary around the area to be removed and use the Extrude tool with the Cut option.
But First
You should view the videos here: http://help.autodesk.com/view/fusion360/ENU/
ETFrench
Fueler
Seen these before. Any particular one you want me to home in on?
