I have a component that is made up of two sketches. Its the ball part from a ball and socket joint attached to a mounting plate.
The ball sketch is a sketch with the revolve tool. The Mount sketch is a sketch with the extrude tool.
I need to combine the two piece into one so I can 3D print it, but there is a gap where the ball socket meets the mounting plate.
In my video...I initially try to lower the component which moves the entire thing...as expected. Then I try to move just the Ball sketch but that doesn't seem to do anything for me. So then I try to drop the body and that looks like it works, but there is part of the sketch at the top of the screen that does not move. So I am unsure if this is the correct way of doing this.
Any advise on how to combine these properly or how I should have designed them differently from the beginning...2 components perhaps?
