Good morning everyone, I am creating an A0 table containing all the quoted drawings of my design, including the flat pattern. Is it possible to completely eliminate the fold lines? I thought to alter the scale of the discontinuous line (like you can do with Autocad) that represents the fold mark. any idea about that?
Thank you all.
Fusion 360 does not have the ability to do this, fold lines yes but not bend lines. There is a work-around but it is a lot of work just to get rid of some bend lines. If you are still interested, take a look at the Screencast.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thank you john for your answer. actually it's a lot of work.In the end the fastest way is to import the dwg into autocad and edit it. Little troubles because if you need to edit something in the original file you lose all the changes made in Autocad, like the setting of line types and colors/thicknesses.
Andrea
