remove fillet
remove fillet
robpage
Message 1 of 14
remove fillet
robpage
I made a fillet to a body.  I worked for a few hours, then decided I wanted to get rid of the fillet.  I can go back in the timeline and edit the fillet, sure, but that's not what I want.  I want it gone completely.  Is there a way to do that?
Replies (13)
Message 2 of 14
michallach81
You can delete fillet feature from the timeline or just pick the fillet and hit delete, this will add delete/remove the feature in the timeline.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 3 of 14
robpage
D'oh!  So simple.  I always see that "xDelete" and think it means to delete the body not a feature.  Have to keep reminding myself.  Thanks!
Message 4 of 14
Thank you, you saved my day!
Message 5 of 14
Delete Don't work for me 😞
(Error message : DeleteFace1 : Compute Failed)
I'm able to open "edit feature" and see my 0.5mm fillet,
but can't "remove selection" because that hide the "ok" button
and can't set it to 0.0mm
Message 6 of 14
chrisplyler
1. If you received that error message, then you probably have made something dependent upon that fillet further down stream in the time line. So if you delete the fillet face, whatever was dependent on it can no longer be calculated.
2. Instead of selecting the fillet face and hitting deleting that, you want to select the fillet FEATURE from your time line, and instead of editing it, delete it.
3. Of course you can't edit a fillet and set it's value to zero. In the same way that you can't create a new fillet feature with a value of zero, it just doesn't make sense.
Message 7 of 14
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Message 8 of 14
What if the model was imported from SolidWorks (I made the switch) so Fusion does not have a history timeline?
Message 9 of 14
interested in exactly the same 🙂
Message 10 of 14
c2_exeger
Observer
Observer
Any news on this issue? I am programming  CAM in Fusion and have created features that I would like to remove in a later stage. Deleting feature makes the model corrupt.
Message 11 of 14
davebYYPCU
Common workflow puts fillets at the end of the timeline for this express reason, can be ignored by stepping the timeline back before the fillets.
For a fillet delete corrupting the file, means you have built later features using the fillet you want to delete. (Sight unseen - generalities can be off the mark.)
Might help....
Message 12 of 14
pulkit.goyalUT2C5
I do not want to show fillet edge in my drawing as it messes up with the dimensions instead will mark up the edges where fillet needs to be, with a Leader Note, but want to show it in the 3D file, which I will share with the CNC guy.
How can I do this?
Dimension highlighted in yellow needs to be 32mm but because of the fillet it became 32.71mm. I want the machinist to know that it needs to be 32mm and then do the round edge. But Because of the fillet edge displayed here, I am not being able to.
Is there any solution for this?
Message 13 of 14
johnsonshiue
Hi! You may want to leverage Configuration workflow. Basically, you need two Configuration members, one with fillets computed and the other one with fillets suppressed. The latter is for documentation purpose.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Message 14 of 14
laughingcreek
you could use edge extension tool in drawings-
